06-12-2021 08:35 PM
I am unfamiliar with Canon laser printers and went through the initial set up and chose no for remote UI. I have a MF743cdw and need to know how to do the set up again so I can choose Remote UI. Thanks.
06-13-2021 02:24 PM
Indeed, access to the printers webserver (remote UI) makes life a lot easier.
See page 371:
Takes about a miniute to set up. After, you will be able to enter the printer's IP in a web browser, then enter the PIN to access the webserver. Take a look at page 428 too.
07-20-2021 02:57 PM
Hello SCALarry,
The steps provided by Shadow sports are correct, if you need to find the printer's ip address so you can access the remote UI, you can use the link HERE for instructions.
