How to print directly instead of using fax? - MF455dw
vishal_sachdev
I have two Canon MF450 multifunctional fax/scanner/printer. One is in the office and one is in the warehouse. We are a small operation so we were using Fax to send documents to each other. Recently, we are having too much intermittency in sending faxes.
I was wondering if there is a way in which I can scan a page or a set of pages in the MF450 in my office, and it can print it in the warehouse machine (same model) via internet connection which is much more reliable, and not analog phone connection.
Any suggestions are appreciated.
3 REPLIES 3
Moderator
Moderator
Thanks for joining the conversation, vishal_sachdev!
So that the Community can help you better, we need to know exactly which Canon printer model you're using from the MF450 series. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
Hey Danny, I am using Canon MF455dw
Hello,
Unfortunately, that model does not have the ability to perform a remote print. The printer would need to receive the print data from something on the local network it is connected to. If you are having problems with faxing, I would suggest contacting support over the phone at 1-800-652-2666 and they can check for any fax issues or help adjust any settings.
