How to deploy drivers through Intune
LonLeeKwok
We have a Canon C7570i copier and i want to deploy the drivers to a group of users.
I have search the web on using Microsoft Azure Intune for the deployment of "Canon Generic Plus UFR II" driver but without result.
Is it possible to do the deployment / setup through Intune? or is there any where i can accomplish this deployment?
thank you.
2 REPLIES 2
Your support request is outside the scope of the forum.  It should probably be directed to Microsoft.
I haven't used intune recently...  but I know it only supports silient deployments that do not require user interaction.  What might work..  try installing the printer on a File Server and deploying to endpoints using group policy.
That might get the job done more quickly while you test and toubleshoot the deployment process to one system using intune which may/may not work.
Moderator
Moderator
Hi, LonLeeKwok!
Thanks for posting! While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
