Different colors of same color text and shapes LBP633Cdw
regularlabs
I have a LBP633Cdw.
I am having issues where text and other elements of the same color print as different colors.
As a test, I have a pdf that contains full green text on a full green background. This should result in a green rectangle, with no text visible.
But the result is this:
Even when exporting the file as a PDF/X-1, I get above result.
Running on a MacOS 14.5, (re)installed the LBP633Cdw PS drivers. Still same issue.
PDF can be downloaded from: https://regl.io/colortest.pdf
0 REPLIES 0
Avatar
