11-13-2023 03:57 PM
Tis printer worked fine up until a few minutes ago. I successfully ran the feed roller cleaning two days ago. Now it won't pull even regular printer paper using the feed roller cleaning. I looked in the manual and it says to clean the roller using a cloth but you can't reach it because it's way inside of the feed area. Any suggestion? The roller actually looks clean. Maybe it's something else?
11-01-2024 12:43 PM
Hello WenSue,
We would be happy to assist with your paper feed issue. To assist further we would need some additional information. You can reply to this message with the information below and we can assist further. For a more immediate resolution or for someone to walk you through troubleshooting the issue, you can contact support over the phone at 1-800-652-2666.
1. What error code do you get along with the paper feed message?
2. What size and type of paper are you trying to print on?
3. Are you loading paper into the front cassette or is it the top paper tray?
11-01-2024 01:20 PM
Haha, well I posted this one year ago (see the date above) so the response is a bit late. Canon has replaced my printer since then
