Canon MF Toolbox
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
‎10-18-2019 12:47 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎10-19-2019 08:43 AM - edited ‎10-19-2019 08:49 AM
This might help. 64bit capable hardware and OS are capable of supporting 32 bit applications.
Maybe you've noticed these in the root of C:\
Program files is the directory where 64bit applications are installed
Prigram Files (x86) is where 32bit applications are installed
What's more likely. The older 32bit software does not support Windows 10. This might be due to its age, not because it is 32bit.
You can try installing the software in compatibility mode. This can allow older applications to run on later versions of windows. Note, this doesn't work in every case and should not be relied on as a long term solution. A future OS update could "break" or render this emulated compatibility.
Here is a general "How To' article so you can become familiar with what compatibility mode does and how it works.
In the end however, I would recommend finding / using updated drivers which supports your hardware under the OS you are using. If this is not possible, (due to its age) consider buying a new device that has support for Windows 10.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎10-19-2019 02:38 PM
Thank you for your reply.
The printer and copier are working fine so I didn't want to put them in compatability mode.
I discovered that MF Toolbox is actually freeware distributed by Canon so I took it off the original disk and set it up on the new laptop.
It loaded (in compatability mode) but wouldn't run. Progress.
I then went to controlled files and put it as an exemption to Windows Defender. Bingo.
All good!
I really like this old B&W printer for everyday work. I have a nice Xerox Phaser color laser that I use for brochures, etc. I can scan color and then print on the Phaser when needed.
Thanks again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎03-24-2020 02:47 PM
I have a new laptop and for the life of me, I download the drivers but I cannot get the printer and the laptop to communicate.
I hear everyone saying their scanner doesn't work but how do you get the printer connected with Windows 10?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎03-24-2020 03:11 PM - edited ‎03-24-2020 03:15 PM
Do you have the original canon printer disk?
Put it in your optical drive and open it.
Drag and drop MF Toolbox to your desk top.
Open MF toolbox on your desktop and it should set up.
I still had an issue so I googled it and found the solution which I explained in my last post. Basically Windows Defender saw it as a security risk and I had to make it an exemption.
My scanner works, copier works, printer works and I don't use the fax.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎03-24-2020 06:51 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎03-24-2020 06:54 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎03-24-2020 08:00 PM
I google and noodle.
Many years ago I was an ET on a nuclear submarine but tech has marched way on.
Do you see the printer on the printer list? The printer set to default?
Was the printer on when you powered up the connected laptop?
At some point you are going to make MF an exception to Windows Defender. Do that now?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎03-24-2020 08:02 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎03-24-2020 08:05 PM
