07-30-2025
03:36 PM
08:00 AM
James_C
Hello, i am trying to install the Canon D480 printer on my windows 11 pc using the following drivers: "[Windows 64bit] imageCLASS D480 MFDrivers (UFR II / FAX / ScanGear)"
I have it plugged in via USB and i can get the printer added but only getting error messages when attempting to print.
I know its no longer supported so i'm wondering if it's possible to print with this machine on Windows 11?
07-30-2025 04:46 PM
The D480 is not officially supported under Windows 11. The last OS it was supported under is Windows 10. Windows 10 drivers may work with Windows 11.
I suggest you visit the product support portal and download the latest drivers available.
Canon Support for imageCLASS D480 | Canon U.S.A., Inc. https://share.google/STeYvptQWYIvjNb13
You indicated that you tried installing Windows 10 drivers. If you plugged the printer in before installing the driver and being prompted to connect it, printing might fail. If these are the steps you followed, I would remove the printer from your Printers Applet dialog, disconnect it from its USB, uninstall the software and restart your system.
Then run the installer again and connect the printer only when prompted. This does not mean it will work but you can try. The printer is 17 years old. Compatibility is not guaranteed.
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
07-30-2025 04:46 PM
07-30-2025 04:58 PM
Thank you. I'll give that a shot!
