10-13-2023
01:56 PM
02:02 PM
SamanthaW
Canon MB 2720 on Windows 11. Printer current version 3.070.
I have been receiving a message for quite some time alerting me that there is a firmware update on the server. I went to Firmware update --> Install update, and received the message "Cannot connect to the server. Please wait a while and try again." I have waited and waited to no avail. I still cannot install the update. This has been going on for months.
Today I installed the latest drivers from the Canon support site to no affect.
In all other respects the printer works fine. I am connected to my home LAN wirelessly and multiple devices can print to it without difficulty including PCs and iPads. I have even explored, for instance, connecting to DropBox without error so I believe I have an internet connection.
10-16-2023 04:53 PM
I am having the same issue. I am connected via LAN wireless and have no problem printing. I have tried for several weeks, several times a day, and get the same message.
12-27-2023 04:19 PM
Hello Kayako,
If you are having problems updating the firmware via wifi, you can try improving the network connection to see if it works. While the printer is off, you can unplug the router from the power for 5 seconds and plug it back in. Once the network is back up, you can try turning the printer on and performing the update. If it still fails, you can try moving the printer closer to the router to improve the signal strength. You can also try connecting the printer to your router with an ethernet cable to see if the update can complete.
07-10-2024 08:10 PM
Why didn't I think of that? Moved it closer to the router and BINGO! Thanks.
02-12-2025 05:44 PM
I got my connection to the server to work by turning off the printer. When I turned it back on, it connected to the server. Update was successful. My printer is connected to a switch on a LAN. I have a different printer, but I don't think that matters. G7020.
02-24-2025 01:52 PM
Power cycling the printer worked for me. Thanks
