12-30-2020
12:56 PM
01:08 PM
my canon printer is on the approved list of printers, but none of my echo show 8 or echo dot 2nd gen or alexa app can discover it.
I updated the printer to most recent firmware v8.01 released November 2020, and IPP is enabled, all devices are on same network, but for some reason it cannot be discovered.
I reached our to alexa support but they were a waste of time, they kept having me try the Canon inkjet skill which does not work for my laser printer , they for some reason do not have a Canon laser printer skill, but my printer 100% is listed on the approved list of discoverable printers
I tried the Canon inkjet skill, but itrequires registration from the printer setup, and it does not let me register since its not in the system
The printer has to go to IJ Cloud Printing Center setup, which only the canon inkjet printer has, no such thing on the Canon imageclass printers.
I am guessing amazon mistakenly thought the laser printers were compatible and added them erroneously to the list
Has anyone able to get this to work with Alexa?
Amazon Certified: Works with Alexa
[link removed per forum guidelines and replaced with a screengrab]
02-14-2021 12:08 PM
I have an older Imageclass mf216n. It worked with Alexa for several months. I needed to change the password on my router at which time the printer ceased to work with Alexa. I removed the printer from my devices in Alexa thinking it would refind printer and I would enter new network password. Alexa could not find my printer. I also called Amazon without success they said if it wasn't on the list it would not work.I don't recall ever setting up a skill in Alexa and the app cannot find my printer. This should not be this difficult. If anyone has the solution, please post.
04-05-2021 06:32 PM
Hello eelee321,
If the printer can't be detected by your Amazon device when it performs a search, you can try unplugging your router from the power for 5 seconds and then plugging it back in. Once the network is back up, you can have your Amazon devices try searching for the printer again. You would not need to install the Canon inkjet skill for the printer to be found.
If the printer is still not found once the network is back up, I would suggest contacting our support team at 1-800-652-2666. They would be more than happy to check your network settings and make sure the printer is communicating properly over your network.
01-27-2025 08:05 AM
I have exactly the same issue. The only "skill" I can find for Alexa is one to check (and order) toner, which requires me to register for some automatic toner refill (not going to do it).
I do have the Canon app on my phone, I can print directly from my phone, but Alexa cannot find the printer.
Amazon says that this printer is compatible, but Alexa just never finds it.
I have even tried switching my Echo devices to the 2G network (since the printer only does 2Ghz and not 5Ghz connections... come on, Canon....)
When I had an HP printer, Alexa immediately found it without any skills or anything. When it died, I replaced it with this printer, and it has never connected to Alexa.
It's very frustrating; because I *DO* use Alexa with my printer, to print out shopping lists, coloring books for my grandson, etc.
01-27-2025 09:01 AM
Hello!
I’m sorry to hear that you’re having trouble with your printer. To help the community assist you better, we need a bit more information:
- What is the exact model of your Canon printer? (It can usually be found on the top or front of the unit.)
- Are you seeing any error messages?
- Which version of Windows or macOS are you using?
- How do you connect to your printer: via USB or Wi-Fi?
Any additional details you provide will help the community better understand your issue.
If you are in the United States and need urgent support, please click HERE to visit your My Canon Account for personalized support options.
If you are outside the USA, please click HERE to find support options for your country.
Thank you, and have a great day!
01-27-2025 10:23 AM
Canon MF656Cdw.
Wireless.
Windows 11
No error messages on printer; only "error" is Alexa unable to find any devices.
Printing from Windows works fine. Printing directly from my phone works fine. Windows machines are wired, printer is wireless. 2 subnets, 192.168.0.x for wired, 192.168.1.x for wireless. Interfaces bridged (and working fine), no protocols blocked (full bridge) on MikroTik Cloud Core Router. Using Ubiquity AC Pro wireless.
