06-23-2019 07:49 AM
After updating W10 update 1903, Canon scanner stop working. Deleting/ Installing Canon driver does not help.
Tried to start Canon MF Netword Scan utility --> won't start
Printing works fine.
06-23-2019 08:37 AM
Hi jouko12341,
Welcome to The Canon Forums, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Forum is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, to go: https://global.canon and select your country or region for your support needs.
06-25-2019 06:15 PM
Hi, I live in the United States and am having a siimlar problem with a MF247dw. Do you know of a solution?
07-01-2019 02:23 PM
Hi Cortlex.
So that we can best assist you, is there an error message that appears on the computer when you attempt to start the scan? Also, have you tried completely uninstalling and reinstalling the drivers and scan utility by following the instructions below?
1. On your computer, open [Control Panel] > [Devices and Printers].
2. Right-click on the MF240 Series printer, and then select [Remove Device].
3. Return to [Control Panel], and then select [Programs] or [Programs and Features] > [Uninstall a Program].
4. Double-click on the MF Scan Utility, and then follow the prompts to uninstall the files.
5. Next, double-click on the MF240 Series, and then follow the prompts to uninstall the files.
5. Restart the computer.
Once the computer restarts, please click the link below to download and reinstall the drivers:
MF240SeriesMFDriverV2175W64usEN.exe
After the drivers have been reinstalled, scan a document.
If you need immediate assistance, or continue to experience an issue, please call us at 1-800-OK-CANON (652-2666), Monday - Friday 10:00 a.m. to 6:30 p.m. ET (excluding holidays).
07-15-2019 05:15 PM
I followed these steps, but it didn't work. I'm still getting the message: "MF Scan Utility that is supported by the scanner you are using may not be installed on your computer. Install the appropriate MF Scan Utility, and then perform the operation again."
