11-07-2023 10:15 AM - last edited on 11-07-2023 12:32 PM by Kristoff
I use a scanner program by the name of Paperport Professional 14 to do my scanning. Worked perfectly for years on all my Canon printer/scanners. Now, I can only scan one page at a time. When I try to scan multiple pages, the ADF does not pull the pages through for scanning but winds up scanning a blank page. Have tried re-installing the software for both the printer and Paperport with no success. Any ideas?
11-07-2023 10:25 AM
Thanks for joining the conversation, russellsmith1!
So that the Community can help you better, we need to know exactly which Canon model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
11-07-2023 12:20 PM
ImageClass 247dw
07-17-2024 03:34 PM
Hello Russelsmith1,
If the Paper Port program is unable to use the ADF program, you can check the scanner settings in the program to make sure it is not set with any photo/image settings. The ADF can only be used with document settings and the paper size set to letter, legal or A4. You can also try downloading and installing our MFscan utility software to see if you are able to scan from the ADF.
