12-23-2012 03:26 PM - edited 12-23-2012 03:27 PM
Using a Canon Selphy CP900 and there appears to be a defect that if you edit the images in Photoshop, the Selphy doesn't recognize the images and refuses to display them on the screen or print them. Just a question mark is displayed. It does this to some images, but not all so I'm thinking it has something to do with the Exif data, but unsure.
There is something on the Canon Support page regarding this error, but no real solution to it.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/se...
Please advise.
03-29-2016 12:51 AM
03-29-2016 10:31 AM
When question mark appears try pressing the zoom+ button. Now you can see your photos. Works for cp910.
03-29-2016 02:07 PM
Try pressing the zoom+ button when you see a question mark instead of a photo.Should see photos when this is done. Works with cp910.
04-06-2016 08:07 AM
That worked great, who would have thought such a simple solution! when I saw the question mark I thought it wouldn't print, thank you very much Dxermike!
06-05-2016 03:53 AM
I found a way around this...
Say You have a Photo that prints with selphy Example: PrintablePhoto.jpg
But you have a different photo that you edited, Got from the net, or made yourself Example: MyAwesomePhoto.jpg
Bring Both the copied PrintablePhoto(1).jpg and The MyAwesomePhoto.jpg Into a editing program
Now Resize MyAwesomePhoto.jpg to the same demetions as PrintablePhoto.jpg and Make your other changes Color correction or whatever you want to add to it. Then when MyAwesomephoto.jpg is how you want it right click it and select cut, now go to Printable image in the editor and right click paste. Now line it all up the way you want it and save PrintablePhoto(1).jpg you can rename it later.
The reason why this works is because printable photo has Information from your camera called Exif Data which is the date and time, Camera it was taken with, excetra But web photos and self created photos don't always have this type of data and so they wont be recognized. By putting the photo you want over one that prints in your photo editor your giving the file the same data as it had from the printable photo but its a different image your tricking it into thinking it was taken on the same day and your tricking it to think it was taken by your camera vs being created.
It still may give you a ? mine did before and after I changed the photo.
But the before photo showed ? and said Cannot Recognize Image
The photo after pasting it over the PrintablePhoto.jpg showed question mark but when I hit Print it printed out just fine.
06-14-2016 08:39 PM - edited 06-14-2016 08:41 PM
THANK YOU DXERMIKE !!
09-05-2016 02:43 PM
Hi Wenz,
thank you so much for publishing this, I can now print my photoshopped photos.
You are a genius!!!!!
Very best wishes
Jane
10-03-2016
03:15 AM
08:38 AM
After much research..i found the absolute easiest fix to this very annoying problem. Go to the picture u r having problems with..open it in another program..i used "paint"....go to save as and change the name to "PrintablePhoto (1).jpg" If u are doing more than on at a time like me...u can use (2) ...(3) etc. Once u print it u can change the name to whatever u like. For me...i had to hit the + button to get the pic to appear once i haf my stick inserted in my printer. Sooo glad i finally got this to work. I was so frusterated. If u need more info or if i didn't mak this easy to understand..hit me uo [email address removed per forum guidelines]. Good Luck!!!
10-03-2016 03:17 AM
10-18-2016 05:49 AM
Thanks this worked - unblievably - for me on CP900
