09-07-2022 09:54 PM
Unable to print via USB or wireless (on same wireless network) via Windows 11. I do not see any drivers on the Canon support site for Windows 11, any advise ?
Thanks
09-08-2022 02:34 PM
As a workaround you can try using the Windows 10 driver for the CP1300. Once you open the support page and it shows your operating system, click Windows 11 and a dropdown menu will appear. Select Windows 10 x64 and then download/install the driver.
09-09-2022 12:09 PM
Hello ArthurJ,
That was the first thing I tried and was unable to install the software. In fact, the driver states that it did not install (either via USB or Wi-Fi). I tried using the same driver on a Win 10 w/s, it installed w/o any issues (both on USB or Wi-Fi). Looks like this driver does not work on any Window versions higher than ver. 10.
Now my issue is, I am getting the following error 'Paper Size is incorrect! Insert paper cassette containing correct paper size.
I am using the following:
Paper Cassette: PCP-CP400
Paper:
Postcard Size (RP-54), 100 x 148mm / 4 x 6 / 4R
Confirm settings, still same error. Do I need a special app to print ?
Please advise, Thanks
03-22-2026 12:17 AM
Salve Arthur, ho installato anch'io da poco Windows 11, ma non ci sono driver per questo sistema, e quello per Windows 10 si Windows 11 non so riescono a scaricare, né con il collegamento USB né in Wifi...
Devo buttare una stampante che funziona benissimo???
Non ci credo! Per favore, dammi una soluzione, grazie
