01-11-2022 01:05 PM
After researching a bit, I found the key wording "or missing".
If your color is just not printing, your print heads may be clogged. Please note, your inkjet cartridge may be clogged too. In which case you'll have to replace it - sorry. Deep cleaning is/was the answer - repeated. After a few cleanings, I switched to deep cleaning. Warning, it uses a lot of ink - the prompt tells you that.
The best solution that worked for me was to reset the WiFi connection and connect to my local Lan. Search for directions on that separately - sorry. Once I used the browser to connect directly to the printer, I first discovered my Firmware needed to be updated. That didn't solve the color printing issue, but it can't hurt to be up to date.
I used the web interface (login: canon, pw: serial number on the printer) to select deep cleaning. Initially, the test pages were only black & white, no color output at all. That's the clue. The printer status shows the color cartridge, but doesn't print color (especially on the test page). After a couple deep cleanings, the color portion of the test page started to print. I ran out of ink on my old cartridge and replaced it. I had to perform a couple more deep cleanings to get full color output from all three colors - problem solved.
I hope this helps at least one person. Best of luck!
02-05-2024 03:29 PM
I am having the same issue but after several deep cleanings and almost an entire color cartridge, I still have no magenta and barely any cyan. Suggestions?
02-14-2024 08:13 AM
If the cleanings and deep cleanings did not resolve the issue, the printer would require service.
If the printer is in it's 1 year warranty, I recommend reaching out to Canon support for your warranty options. You will need to register your Canon gear HERE to access additional support options.
If the printer is out of warranty, you would qualify for the Canon Upgrade program. This is for out of warranty units which have been diagnosed to require service or are incompatible with a new or upgraded system. This program allows you the opportunity to purchase a replacement product discounted from the list price. Free ground shipping is included with your purchase.
If you would like to take advantage of this offer, please call our Sales Department at (866) 443-8002 Mon-Sat, 9 AM to 9pm EST excluding holidays.
Did this answer your question? Please click the Accept as Solution button so that others may find the answer as well
