03-15-2026
10:13 PM
08:15 AM
James_C
Printer worked fine, sat for 2 months and now I can’t print anything. I have uninstalled and reinstalled the drivers 4 times. I have 2 printers telling me the same thing. Printer not responding. I’m on windows 10 pro. New ink in both. Can anyone help?
03-17-2026 02:28 PM
If you installed the drivers while the usb cord was connected, please disconnect the printer and remove the printer drivers.
Once the drivers are removed, please restart your computer and leave the usb cord disconnected. After the restart, click HERE to open the support page for the printer. Once the page opens, make sure Windows 10 is listed as the operating system then scroll down and install this file: iP100 series Printer Driver Ver. 2.17b
Leave the scanner disconnected until a message appears asking to you to connect the printer. Once connected the computer will detect the printer and finish the install. Once that is done, try to print again.
03-23-2026 04:59 PM
Did not work. And can’t use them with windows 11
