Driver for Pixma IP90 in Win10
DH371
Hi, I've used a Pixma IP90 for travel for years. When I changed to Win10 about 3 years ago I found a driver on the Canon Far Eastern website which worked perfectly. I recently changed my laptop and the driver on the Far East site is the same as on all Canon sites, it only allows printing in B&W. Does anyone have access to a driver for Win 10 which gives funtionality to print in colour ? Thanks !
FatboyJim
Hi Shadowports / DH371, newbie poster but a Canon PIXMA iP90 user for <cough> 15+ years (same printer!)... I've recently purchased a Windows10 (64-bit) laptop and have been having issues getting my PIXMA iP90 running at all (previous laptop upgraded from Windows7 to 10 so was running fine!).
I tried the iP90 driver in Windows7 compatibility mode as Shadowports suggested, but had no joy. Windows10 kept reporting 'no driver' when adding via USB and nothing seen with bluetooth (BT-001), so thought I would have to finally hang up its leads.
While searching for a suitable replacement (PIXMA TR150) I had a flash that I'd not tried the newer PIXMA iP90v driver, so downloaded from Canon (v 2_00a-ea21), set the executable to Windows7 compatibility (via properties), plugged the USB in and Windows10 immediately picked up as an iP90, printing a test page perfectly.
Added a 2nd printer (copy) and changed the port properties to BT-001, unplugged the USB and Bluetooth test page printed straight away too.
Thank you both for the suggestions and pointers (even 3 years on!) ... not so sure my iP90 will be so happy - it was probably looking forward to retirement!
6 REPLIES 6
Canon recommends installing the W7 driver in compatibility mode.  I don't see anything about the W7 driver being limited to print B&W only.
Pixima IP90
~R5 C (1.0.2.1) ~RF Trinity, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring
~6D2 (v1.1.1) Retiring ~EF Trinity, others ~DxO PhotoLab Elite ~Windows10/11 Pro ~EVGA RTX 3080Ti FTW3 Ultra ~ImageClass MF644Cdw ~Pixel6 ~CarePaks Are Worth It
Thanks, I'll give it a shot - David
Hi Shadowsports, thought i should send a follow up reply in case anyone is looking for aswers to the same problem. Unfortunately I have not been able to try the win 7 driver as I am unable to get the printer to power up. I have asked about this in a separate post and it sounds as thought the printer is dead - it was a very old printer !  Thanks anyway, David
FatboyJim
DH371
Smart thinking FatboyJim - well done! Sadly I no longer have that printer as after a long life it seems some essential component had died. Good luck with yours .
stn79
There are Windows 10 drivers for the ip90, but Windows Update doesn't automatically load them. You have to manually download them from the Microsoft Catalog (catalog.update.microsoft.com) and install them manually
I wrote a tutorial here: https://community.usa.canon.com/t5/Mobile-Compact-Printers/Can-t-get-PIXMA-ip90-to-work-on-Win10/m-p...
03/14/2023: New firmware version 1.8.1 is available for EOS R6
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.0
01/18/2023: New firmware version 1.1.1 is available for EOS R6 Mark II
11/22/2022: New firmware available for EOS R3, EOS R7 and EOS R10
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
