wish to scan 110 mm color negatives on canoscan 5600f.
sverny
How does one shut off the auto-sensing of negatives on the canoscan 5600F?  I should be able to preview the smaller 110 format and just crop around the smaller frames yet I cant even get to the preview window without the error that the film can't be detected.
Patrick
Hi sverny,
Scanning 110 film is not supported with the CanoScan 5600F.  You can try scanning with Thumbnail View turned off, but there is no guarantee that this will work:
 1.  Open the MP Navigator EX program.
 2.  Point to Scan/Import and click Film.
 3.  Select the Use the scanner driver checkbox, then click Open Scanner Driver.
 4.  Click Advanced Mode.
 5.  Next to Select Source, choose Film.
 6.  Click the Thumbnail button in the upper left hand corner of ScanGear to disable this view.
 7.  Click Preview.
 8.  Manually crop the images.
 9.  Click Scan.
2 REPLIES 2
Patrick
Hi sverny,
 7.  Click Preview.
 9.  Click Scan.
Tried it and it works. I just have to make sure the 110 negative is aligned fairly straight between the holder. Thanks.
