05-05-2013 03:58 AM
refurbished slr camera?
what does it mean? it is used already?
2nd hand?
or with small damaged camera??
05-05-2013 04:51 PM
I don't know what Canon's policy is on refurbished product, so they can jump in and correct me if the following is wrong, but in general: refurbished product was something at was returned as opposed to something that was simply used and then sold. A refurb could be something used during a 30 day return window and sent back, or something that had a defect and was returned, floor model, etc. But a refurb will be rebuilt to spec and 100% tested, and usually comes with a warranty for a reasonable time period. Most companies use lot inspection, meaning that they test samples from each batch made and if the samples are ok they assume everything is. A refurb will be 100% inspected, which is more than you can say for the product that you buy brand new.
Personally I have zero qualms about buying a refurb lens from Canon and I have very little issue buying a camera body. You never know what's inside with electronics so I guess I have a little hesitancy with the Camera bodies. But if the price difference is significant to me, then I'd do it without regret.
05-06-2013 10:47 AM
05-06-2013 11:38 AM
05-09-2013 10:34 AM
Skirball you make a great point!
Resty... I would recommend refurbished products if you find a good deal. A lot of lens I try out I would test them prior to purchase. I never had a Canon Lens issue or malfunction on lenses and some are very old! They are made very well.
05-10-2013 01:33 AM
thanks for ur help guys.. so were is the best shop can i buy the refurb one?? on cannon website?? thankx
05-10-2013 07:37 AM
05-20-2013 07:38 AM
Refurbish implies to me previously used or repaired. Although they may be perfectly fine, when I see their price, the savings are not worth it when comparred to getting a brand new item with a warranty.
