lide 400 scanner
jpapas72
Good evening. I have the canon lide 400 for about 5 months. While it was working normally all this time suddenly while I press the copy button on the front of the scanner the result is a white page. The device works fine otherwise. While there is a document inside the machine when I want a copy the result is a blank page. I uninstalled and reinstalled the machine but the result is the same. Do you have something to say to help me?
12 REPLIES 12
Moderator
Moderator
Hi, jpapas72!
So that the Community can help you better, we need to know exactly which operating system is running on your computer (i.e. Windows or Mac OS, and which version thereof) along with what printer make and model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
Sorry, I use windows 10 64bit and my prnder is epson L310. The problem ia that the scanner with the printer working perfect before 1 week
janstehlik
same here - lide 220
Sole200q
Same problem with lide 400 and printing to hp 1102p
Hallo again. Can you halp me ?
thank you very much for the advice. You helped me a lot. Thank you again
Patrick
Hi jpapas72,
Losing the Copy function is related to the installation of the latest update from Microsoft.
Rolling back the update or waiting for an update from Microsoft is recommended.
If you wish to keep or reinstall the KB5000802 update, please also install KB5001567 and KB5001649.
Microsoft issued those newer updates to resolve the issues with KB5000802.
