06-05-2016 06:18 PM
06-05-2016 06:24 PM
If you are just trying to get the photos off the camera:
For several reasons most people would probably sluggers you take the camera's memory card out and then just use a card reader to upload the images to storage.
If you are trying to shoot with the camera "tethered" to a laptop so you can see the images as you shoot, that is a different question.
06-06-2016 04:17 AM
USB cable.
It came with your camera unless it was a used one and somebody didn't give one to you.
Nothing else is required.
06-06-2016 12:50 PM
@ebiggs1 wrote:USB cable.
But you can no longer count on using the same cable for all your cameras. For the longest time all Canon cameras had a mini-USB port. But I was annoyed to discover that the 7D Mark II uses micro-USB. ![]()
06-07-2016 03:56 PM
I am guessing that is due to the fact that it is USB 3.0
06-07-2016 04:21 PM
@kvbarkley wrote:I am guessing that is due to the fact that it is USB 3.0
Indirectly, I suppose. They probably decided that a mini-USB 3.0 port would take up too much space.
I'd gladly give up the extra speed for the compatibility of a USB 2.0 port. I always use a card reader, so almost the only reason I connect directly to a computer is to synchronize the time between my wife's 7D2 and my cameras when we're about to do a photo shoot together.
