canon printer problem
wanda1
I have both a Canon printer and a hp printer. My Canon printer was connected with my computer earlier. So when I tried to connect my hp printer, I faced an error that occurred at that time. I learned about [removed per Forum Guidelines] after searching many websites and got the solution. But after that suddenly my Canon printer stopped working. What should I do now?
1 REPLY 1
Stephen
Moderator
Moderator
Hello!
So that the Community can help you better, we will need to know exactly what model printer you're using (it's usually on the top or front of the unit), any error messages you're seeing, and the Computer Operating System you're using (Windows Vista/7/8/10 or macOS 10.x), as well as the way you connect to your device (USB or networked via WiFi or Ethernet).
If you're in the United States, and this is an urgent support need, please click HERE to enter your product information and discover your support options.
If you're outside of the USA, please click HERE to find support options in your country.
Thanks and have a great day!
Avatar
