12-19-2018 02:48 PM
I am sorry if this isn´t the right place to ask.
I have a big group of old photographs on paper to scan with a Canon scanner (with max. res. 9600 dpi) to use in a video documentary that will be shot with a C300 Mark II in 4K.
What resolution do I need to scan this old photographs for this kind of video use?
TIFF or JPEG scans?
Thank you very much
12-21-2018 09:48 AM
Please; if there is a Canon scanner forum; let me know. I am not finding one. Thanks.
12-24-2018 10:50 AM
Hi Cunha,
I would recommend scanning at 600 dpi. That will be useful if you need to zoom in on any of the scans. I would also save as TIFF.
12-24-2018 02:26 PM
Hi Arthur,
thanks for your help.
01-02-2019 11:13 AM
Scanning at 600dpi will probably be sufficient, but it doesn't automatically provide you with a 3840x2160 pixel image file. Your finished scanned image dimensions are determined by a combination of scanning resolution and and the physical size of the prints you're scanning at a given resolution. Remember that "DPI" stands for dots per inch.
Scanning a 4x6 print at 600dpi produces a 2400x3600 pixel image. But scanning an 8x10 print at 600dpi will produce a 4800x6000 pixel image. As a rule of thumb, small prints would be best scanned at higher resolution (dpi) and larger prints could be scanned at lower resolutions.
Scanning everything at excessively high resolution will slow down the scanning process unnecessarily. And saving these huge files as TIFFs will make humongous file sizes. They may also be slow to open and edit depending on your computer's hardware and software.
01-03-2019 07:58 AM
Thank you BurnUnit.
01-03-2019 09:18 PM
BAM! You've got a grasp on the pixel dimensions and the minimum scanning resolution to get there. It's essentially the same as figuring the square footage of an 8' x 10' floor when you're buying tiles. Except the pixels are tinier than the tiles and there's a whole bunch more of them. But the math is the same.
If you're planning on filling all or most of a 4K screen, then scanning at 600dpi is probably a good place to start. If they're larger prints it will still give you a little room to crop or zoom out and still fill all or most of a 3840x2160 screen. If you have to do any editing to the scans then a TIFF file would be the way to go. But you may still want to convert them to highest quality jpegs to add them to your video. It's just that since you mentioned that your scanner could go to 9600dpi I was afraid that you were thinking of diving into the deep end of the pool. Even scanning at 2000 or 4000 dpi would be overkill and saving them as TIFFs is going to make for a huge file size. I don't know what you're using for video or image editing software or if your computer is up to snuff. But the big TIFF files could really bog down your workflow. At least they would on my computer.
01-04-2019 10:19 AM
BAM! ,-) A grasp with some nice help.
Thanks a lot.
Hope this helps others.
Cheers.
