02-19-2013 12:52 PM
Because 'normal' and 'fit to page' layouts cut off left side of printed material I'm using 'borderless' layout but that doesn't give me the paper size option I need. Any hints on how to save the left side of paper and how to change paper size in borderless layout. Any hints in print preview wherein I can print just 'one or two' of multiple pages without having to return to the set-up page?
02-25-2013 10:16 PM
Hi vitaminsg,
In order to properly answer your qusetion we will need a little more information. Please let us know whether this happens in multiple programs or only one particular program. If it is only one program, which one? Also, what version of Windows or Mac are you using?
02-25-2013 11:19 PM
i'm using Windows 7 Home Premium. Printing problem happens in all programs i.e.Quick Books invoices etc., Microsoft Word when printing correspondence, Quicken when printing reports. I did figure out that if I change print layout to normal or fit to page I can change the margins so that the left side of page does not get cut off but I don't want to have to do this every time I print something. I jsut want to print without all the hassle of having to set the margin each time. Any thoughts on changing the default ?(not sure if that is the correct question.)
02-26-2013 11:30 PM - last edited on 02-26-2013 11:54 PM by Naomi
Hi vitaminsg,
You can set it so that "Fit to Page" printing is the default setting. To do this, use the following steps:
1. Click Start.
2. Click Control Panel.
3. Click Printers and other Hardware.
4. Click Printers and Faxes.
5. Right click the PIXMA MX432 and click Printing Preferences.
6. Click the Page Setup Tab.
7. Select Fit to Page under Page Layout, then press OK.
This should now be the default setting for all programs.
02-27-2013 01:35 PM
PERFECT! Thank you....
