08-25-2015 10:21 AM
I am stuck between ordering these two LED lights for indoor low lighting pictures. I have a fixed 50 mm 2.8/F lens but still dont think it's enough . I saw these two styles of lamps but was told by a local photography shop the circular lights are more for upclose portraits and recommended the squared LED. I'll be walking around taking pictures.
Any suggestions?????
Using Canon 3ti
50mm and 15-55mm lens
thank you
08-25-2015 10:52 AM - edited 08-25-2015 10:57 AM
Get an external flash instead.
Your T3i can act as a master flash so you can even get the external flash off camera for even better results.
Canon recently updated their 430EX flash, so the 430EX II is selling at what I consider a good price.
08-25-2015 11:02 AM
I think you can't go wrong with the Canon 430EX II (I editied my post above).
08-25-2015 10:54 AM
Won't I need someone to carry that around?
Just to make sure you're talking about a flash that is not connected to the camera correct?
08-25-2015 10:58 AM
@Adrianpz1 wrote:Won't I need someone to carry that around?
It can be used on camera or off camera.
08-25-2015 11:00 AM
Is there a brand you recommend? I'll definetely look into this.
thanks again TTMartin
08-25-2015 11:02 AM
08-26-2015 02:07 AM
