06-25-2016 12:59 AM
I'm using Image Garden to create DVD Labels that I use once a year for graduation DVDs. However, I need a way backup my labels for obvious reasons of hardware or operating system failures. Judging from a couple other posts on this, it, unbelievably appears as though there is no way to save your work to an alternate location or copy your finished label file to a server or backup device. Is this true? I can't fine my labels anywhere on my system drive, including under the ..\appdata\roaming\canon folder. Anyone know where or how they are saved? I can't imagine any reason why Canon would go this far out of their way to hide a user's work.
06-27-2016 08:15 AM
Hi Dudeman44.
You are correct, there isn't a way to save created DVD labels when using My Image Garden. At this time there are no plans ot add this functionality to this program.
06-27-2016 08:15 AM
Hi Dudeman44.
06-27-2016 11:07 AM
Surprisingly candid answer, more importantly, what is the reason for this? I can't remember working with nearly ANY product, since DOS days, that purposely omits this obvious ability. Why would you do this, it almost kills the usability of this application?
06-27-2016 11:45 AM
What if you "printed" the output to a PDF file, instead of a printer?
08-02-2016 10:36 PM
Unfortunately, It only lists the cannon printer for the printer selections.
