Image Garden
Dudeman44
I'm using Image Garden to create DVD Labels that I use once a year for graduation DVDs. However, I need a way backup my labels for obvious reasons of hardware or operating system failures. Judging from a couple other posts on this, it, unbelievably appears as though there is no way to save your work to an alternate location or copy your finished label file to a server or backup device. Is this true? I can't fine my labels anywhere on my system drive, including under the ..\appdata\roaming\canon folder. Anyone know where or how they are saved? I can't imagine any reason why Canon would go this far out of their way to hide a user's work.
Patrick
Hi Dudeman44.
You are correct, there isn't a way to save created DVD labels when using My Image Garden.  At this time there are no plans ot add this functionality to this program.
4 REPLIES 4
Patrick
Hi Dudeman44.
Surprisingly candid answer, more importantly, what is the reason for this? I can't remember working with nearly ANY product, since DOS days, that purposely omits this obvious ability. Why would you do this, it almost kills the usability of this application?
What if you "printed" the output to a PDF file, instead of a printer?
Unfortunately, It only lists the cannon printer for the printer selections.
Holiday
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R5C - Version 1.1.1.1
EOS C80 - Version 1.0.3.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
