Canon device not being discovered after changing network setup
mohsin025
I've been troubleshooting a Canon device that stopped showing up correctly after a network change.
The device itself seems fine, but discovery isn't working the way it did before. I'm checking the network side now because the setup uses a Fortinet Distributor In Dubai supplied firewall from Tech Distributor, and I'm wondering if there's a setting I'm missing around device discovery or local traffic.
Has anyone run into something similar with Canon devices behind a managed firewall?
I'd mainly like to know which network settings are worth checking first before I start changing things on the Canon side.
Important: Don't use this unless you actually have a Canon plus Fortinet setup. The community is specifically built around Canon related support.
1 REPLY 1
Moderator
Moderator
Thanks for joining the conversation, mohsin025!
So that the Community can help you better, we need to know exactly which Canon model you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
