09-22-2013 11:09 PM
I like this scanner. It has good quality scans but has a severe problem.
90% of the shades of green are scanned as blue. I have a very nice computer with windows 7, plenty of memory, and a fairly decent video card.
I was wondering if this scanner is defective. It will be hard to return this to the store. I have owned several scanners at home and at work and none have scanned colors wrong. Any suggestions would be very much appreciated.
Thank you.
09-25-2013 12:49 PM
Hi EastOU,
A couple questions for you:
09-25-2013 10:21 PM
We have about 90 albums of photographs that I am scanning. Being 40 years of pictures, the type of cameras range from 110 through 35 mm. They are all color photographs. I use Zoner Photo Studio 15 for my base software. The scanning software is what comes with the scanner.
09-25-2013 10:23 PM
The scans appear sharp and clear. I have not scanned anything other then photos. I have not adjusted any settings. I am not sure exactly how to change the settings in Zoner. Zoner has a really nice feature that let's me edit the picture and apply the right color but of course that is very time consuming.
09-25-2013 11:49 PM
Hi again EastOU,
We can calibrate the scanner to see if this will resolve the issue you are experiencing. To do this, please follow these steps:
2. On the "Scanner" tab, the Calibration options can be found. Click Execute to begin the calibration process.
3. The calibration process may last anywhere from 1 to 2 minutes.
When the above window disappears from the screen, then the calibration is complete. Repeat the calibration up to 3 times if the desired results are not achieved.
Hope this helps!
09-28-2013 12:53 AM
Thanks for your reply. I had already found this calibration option. I tried it several times without success. What's funny is that when I go into Zoner Studio, select the area that should be green by using effects and shift colors, the selected area changes to almost the exact color of green in the picture.
