Which tele extender should I buy? 1.4x vs 2x, series II vs series III
FredSchall
I would like to purchase a Canon tele extender. Do I want a 1.4x or 2x and do I want series II or series III. Advantages, disadvantages? Thoughts? No big deal on series? Thanks
14 REPLIES 14
ebiggs1
"How about the 1.4 on a 100-400 ef usm II. ??"
I wouldn't do it personally but some guys tell me it works fairly well. Also John's advice, which I totally agree with, is using a top of the line camera. When you start adding a tel-con that makes s huge difference. I don't remember what camera, perhaps you said, that you are using this on.
I would go the crop route first before you spend your money. You may be well satisfied. Go d/l DPP4 and try it.
wq9nsc
Fred, the answer also depends on your intended use.  Any extender will somewhat reduce autofocus performance, it isn't just the extender adding to the overhead of the AF algorithm but also the fact that you are losing one or two stops of light which reduces AF speed due to reduced performance of the AF sensor in lower light.  So it is more of a problem for action shots like sports or wildlife.  AF on the better bodies will still work quite well but not as well as they do without the extender so it is one of the compromises you have to consider.
I have a couple of flavors of the Canon 1.4X (versions II and III) and both work pretty well with my EF 70-200 f2.8  and fast telephoto primes. I usually keep the 1.4X in a bag with me in case some unexpected need comes up but the only times I have used it in the last few years was for a few baseball games combined with the 400 f2.8 when shooting batters from behind the outfield fence and with my 800 f5.6 when shooting eagles and that combination requires a lot of collaboration between the camera and user to have the subject in focus at the exact point and time needed.
I also have a Canon 2X and although it can produce decent images with the EF 300 and EF 400 f2.8 glass, the images are clearly impaired compared to what these extremely sharp lenses can produce by themselves.  The results with a 2X will be far worse on lesser glass and I would avoid the 2X.  Also, a lot of camera body/lens combinations won't autofocus with a 2X extender.
Realistically, if you feel you are going to be using the extender for a very large percentage of your photos then you need to compare the extender/lens combination to the results from one of the 150-600 setups.
Rodger
Thank you so much for you terrific and very thorough explanation. I really appreciate it.
Take care. Fred
Thank you so much for your terrific and very thorough explanation. I really appreciate it.
Take care. Fred
Hello guys, I have used a 1.4x on my EF 100-400mm L mk 1 lens for years. both with my 5D mk II, 1DSmkIII and 1DX. I have had very good results with it even when cropping some, I will attach a few samples for you guys. Very powerful small combo. You will loose all but the centre 5 focus points work fine with this and still AF works very well.
Holiday
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R5C - Version 1.1.1.1
EOS C80 - Version 1.0.3.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
