New Camera guidance: Gear recos for family, sport, and concert photography
raremom_2
I was gifted the EOS Rebel T6 camera with the double zoom lenses that came with the “kit” about 9 years ago. I have been getting more into family, sport, and indoor/ outdoor concert photography and I feel like I am needing some an upgrade.
Just looking for some recommendations on upgrades! Thanks in advance.
7 REPLIES 7
I completely understand. It's a 10-year-old camera, 18 megapixels digic 4+ processor, 9 AF points and a max ISO of 6400.  There isn't one performance standard  that won't be improved with an upgrade.
What are you not getting from your T6 and lenses?  What is lacking or what are you looking to improve?
Do you have a budget for the upgrade?
I don’t feel like it’s very quick when I’m shooting, and when I’m doing my indoor shows I feel it struggles to keep up with the constant changing from the backlighting. Just looking for recommendations right now before we set an actual budget since it’s something that it used all of the time.
stevet1
raremom_2,
As far as recommendations go, the problem isn't going to be the lack of them, it's going to be a list of recommendations that is a yard long.
As Rick said, it would be helpful to know what you have to spend, or what you want to spend.
It doesn't do either party any good to recommend a $5,000 camera to you if you only have $500 to spend.
You might think about some of the things you want to see in a camera. I have a T6, and whenI went to upgrade it, I wanted a camera that had more focus points, had a faster burst rate, an articulating LCD screen, and a faster processor.
The T6 only has a Digic 4+ processor. Canon is now making cameras with a Digic X processor. The difference is night and day better.
So, some questions to start off with:
1) How much do you want to spend?
2) Do you want to stay with DSLR, or would you like to move to mirrorless?
3) Is weight an issue or a factor? The older I get, the more weight becomes a factor in my decision-making process.
4) is taking videos, as well as taking still photos, important? The T6 records movies in the QuickTime .mov format. You might want to look for a camera that records movies in the more generally accepted .mp4 format.
These are just some questions to get you started.
Steve Thomas
So, I'm going to focus on "indoor shows" since you did.  First, before you consider a camera you might want to focus on your lenses.  If you have really nice full-frame EF lenses and are happy with the quality, then the smallest step up would be an cropped sensor RF camera with an adapter to put the lenses on.  This will almost prove dissatisfying to some degree and you can upgrade to RF lenses over time.   If, however, you are using EF-S lenses then you'll want to start from scratch and add RF lenses to your shopping list first.
In either case start by getting your focus (pun intended) on what lens or lenses you're going to get a camera to drive them.  Cameras come and go but a great lens can serve you 20 years or more.
Full frame RF will have better low light performance than cropped sensor RF.  IBIS (in-body image stabilization) will have better low light performance than non IBIS cameras.  IS (image stabilization) lenses will have better low light performance than non-IS lenses.  In general, and especially on full-frame, Canon L lenses will have superior image quality than non-L lenses.  On cropped sensor cameras using full-frame lenses you lose the corners of the lens, and that's where budget lenses usually are weakest.
Hopefully this gives you some ideas and you can start to research and then ask us more specific questions that might help us point you in a direction that will be most satisfactory to you.
For instance, if you're at distance and shooting indoors, and on a moderate budget I might suggest the R6 Mark II or Mark III and the RF 70-200mm f/2.8 L USM.  The R6 is the lower end of the line with IBIS    If you had a bigger budget then the step up to the R5 Mark II and getting the RF 70-200 f/2.8 L USM Z would be a great combination.  If you're on a much tighter budget then the R50 or R10 with the RF 24-105mm F/4-7.1 Is STM (or, my second choice as I'd prefer a full-frame lens in case I ever upgraded to full-frame) RF-S 18-150mm f/3.5-6.3 IS STM Lens might be a good consideration.
Budget and your shooting priorities will make a big difference in what is recommended.
Plus>> Canon imagePROGRAF PRO-1100 Printer. My photos are edited using Canon Photo Professional and no Adobe products.
Look into the R6 Mark III package with 24-105 f/4L lens.
https://www.usa.canon.com/shop/p/eos-r6-mark-iii-rf24-105mm-f4-l-is-usm-lens-kit
Or, if $4,000 is too much, refurbished R6 Mark II is $1900 right now if you have existing lenses. R6 Mark II and RF RF24-105mm F4-7.1 IS STM for $2400 seems like a pretty good full-frame kit bargain to me.  Of course I'm biased.  I own those.
https://www.usa.canon.com/shop/p/eos-r6-mark-ii-rf24-105mm-f4-7-1-is-stm-lens-kit?color=Black&type=N...
ebiggs1
" I feel like I am needing some an upgrade."
From what you said it sounds like you need a replacement more than just and 'upgrade'. However, remember all the fancy new features of the newest cameras are useless if you don't need or use them. You can spend thousands of dollars for a camera that will shoot anything, anywhere, anytime and even wash and dry the dishes. But if you eat out all the  time that feature is not worth it. 😁
Any new camera is going to do everything better and faster than your Rebel T6. So, the market is wide open. The suggestions above are quite confusing. Keep in mind you have a consumer grade beginner level Rebel with kit lenses. Some suggestions made are for prosumer or pro level camera and lenses. Do you need that level of 'upgrade'? Maybe you do. How about budget for it?
There is probably a lot that can be done that will enhance your T6 for your intended purpose. One thing if you haven't already done it is to d/l DPP4 form Canon. It is free so no good reason not to. Post editing can make a so-so image into a great image. Second always, always shoot raw. Raw has extended latitude in the editing process for example exposure can sometimes get 3 or 4 stops more, or less, as needed exposure. Raw always captures the full amount of resolution and data from the camera while jpg discards quit a bit of data never to be recovered. Data that could be used in post.
You might try this first before you go shopping.
EOS 1DX and many lenses.
