Any value in purchasing a polarizer filter for my Canon R5 MKII when shooting in RAW?
watash1965
Enthusiast
Is there any value in purchasing a polarizer filter for my Canon R5 MKII when shooting in RAW?
Watash1965
2 ACCEPTED SOLUTIONS
jrhoffman75
Watash1965
A polarizing filter helps reduce glare off certain surfaces like water and leaves. If that is a problem you are having then CPL could help. Be aware that using it with wide angle lenses can cause undesirable effects in the sky due to the wide variation in the angle of the sun.
johnrmoyer
Watash1965
I think https://en.wikipedia.org/wiki/Polarizing_filter_(photography) has a  good explanation with examples. Some filters can be done later in software when shooting raw, but the polarizing filter cannot be duplicated in software.
As @jrhoffman75 already mentioned, the light from the sky has different polarization depending upon angle with a result being that some parts of the sky are much darker than others when using a wide angle lens with a polarizing filter.
2 REPLIES 2
jrhoffman75
Watash1965
johnrmoyer
Watash1965
