04-22-2018 09:05 PM
Is there a Canon camera that will allow you to set the start, end points and number of shots to take?
04-23-2018 01:46 PM - edited 04-23-2018 01:51 PM
Yes. Use the app DSLR controller and you have the focus stacking function. There are some discussions here :
04-23-2018 08:56 AM
04-23-2018 10:10 AM
You can do it with any camera in post.
04-23-2018 01:28 PM
I think my CamRanger does this (I don't use it for that), but that's an expensive solution.
Refocusing a lens can cause some difference based on focus-breathing (that's where the true focal length changes just be shifting focus). If you are interested in focus-stacking specifically for macro photogoraphy, the common solution is to use a "focus rail". This mounts the entire camera on a rail (attached to a tripod) and the rail allows the entire camera to slide forward/backward (my rail has about 11 cm worth of travel). You shoot, move it a few millimeters & repeat until you have enough frames. But it's not automatic.
