Canon 400D Error 5
Deusa
I have two lenses one Zoom 300 and the other 18-55 standard lens
With the zoom all works as it should and produces excellent results
However with the standard lens it only works if I manually lift the flash unit and the flash flashes in the normal fashion but if I try and use the camera during the day ( or do not lift the flash )it shows "ERROR 05 The built in fast auto popup was obstructed turn off and on again" however the error will not go away
Urgent please advise what I can do to stop this error message and be able to use the camera with the normal lens without Flash.
Thank you
Regards
Robert
0 REPLIES 0
