03-16-2022 03:24 PM
Hello,
I am running into an incredibly frustrating problem when trying to use my PowerShot SX740 HS as a webcam. I have installed the Canon EOS Webcam Utility software and the SX740 is compatible. However, as soon as I plug the camera into my computer via a USB cable, the lens retracts and the shutter closes. It shows the computer icon on the screen of the camera but that is it. I can transfer photo/video files via the USB connection without issue. The camera is also in Movie Mode. Any ideas?
Thanks,
Dillon
04-28-2022 01:18 PM
03-17-2022 08:27 AM
Hi, Dillon! EOS Webcam Utility works with the PowerShot G7 X Mark III, the PowerShot G5 X Mark II, and the PowerShot SX70 HS. We're unable to ensure compatibility with other PowerShot camera models. You can check out the complete list of supported camera models right here.
Hope this helps!
04-28-2022 12:14 PM
I don't understand this answer at all, you link to a page that list that PowerShot SX740 HS as supported. Is it possible to get a correct answer?
I have the same problem please and thanks in advance
04-28-2022 12:18 PM
Yes… It was very much a non-answer wasn’t it? I ended up returning this camera, so I unfortunately can’t point you in the right direction. Canon does offer a callback Service however, you can submit a request to have a tech phone you to troubleshoot. Not sure if it would be helpful, but it’s worth a shot. But I can 100% relate to your frustration, such an annoying problem with no clear answer
04-28-2022 01:07 PM
What's Confusing about Danny's answer?
Powershot sx740HS is not listed as supported on the WebCam Utility download page:
Nor is it listed on the 740's download page:
This might not be the answer you both are hoping for, but its not officially supported. If you want WebCam support, choose a supported model to ensure compatibility.
04-28-2022 01:18 PM
I think we both misread SX70HS as SX740HS
04-28-2022 11:05 PM - edited 04-28-2022 11:10 PM
I did a search on line and checked multiple sources of information on this issue. The PS SX740 is NOT compatible or supported for use as a webcam.
For example, see:
Canon U.S.A., Inc. | EOS Webcam Utility
Which Canon Cameras Can Be Used As A Webcam? (Full List) (bwillcreative.com)
It cannot be assumed that any camera can be used as a webcam - that is true of any brand. Did you research this before you committed to buy?
04-28-2022 11:08 PM - edited 04-28-2022 11:11 PM
Honestly, it appears that you did not research this beforehand, if you did you would find that unless a camera is listed as compatible, it is not supported. The SX740 is clearly not listed in Canon's and others' published lists of supported cameras for webcam use.
04-29-2022 07:40 AM
As I said below, I misread SX70HS as SX740HS. My mistake. Camera has been returned.
04-29-2022 05:27 PM
Might be a good idea to mark this thread as resolved, then you won't be bombarded with people trying to resolve this for you! {:-)
