WARNING Webcam Utility DOES NOT WORK with Mac M1 running Big Sur versions past 11.0
reeceguida
I want to save others the trouble: Webcam Utility will ONLY work for Mac M1 (AKA the 2020 models that don't have the Intel Chips) running Big Sur 11.0. Stop searching for a fix because there isn't one.
Canon: is adding support for this on your Webcam Utility roadmap? Can you PLEASE post a fix to your software? My only option is to revert back to Big Sur 11.0, and I can't do that because I don't have a backup.
I was so excited to use this beautiful camera for work/streaming and now I feel like I just put money in a paper shredder. I will glady return it for another if there's no promise of a fix.
60 REPLIES 60
Yet again you seem to be misinformed about developing for Apple products. The change to Apple Silicon required no such “Apple school” - most of them required a simple recompile as a bare minimum and with a bit of effort could be improved by the switch by making use of publicly available API’s which they probably should have been using anyway.
Friends and Family
