06-16-2020 01:12 AM - edited 06-16-2020 01:12 AM
I've been trying to use my Canon m50 within OBS via the Webcam Utility.
Unfortunatly I haven't been able to do it on two seperate Macbook pros. I upgraded one from High Sierra to Catalina to see if that would make a difference but no go. I don't have EOS Utility. It worked flawlessly with the Zoom app but not on OBS. Now it's not showing up on Zoom after the upgrade. The camera showed up once on OBS but I haven't been able to do it again.
Any ideas?
Thanks!
06-16-2020 08:24 AM
The webcam utility was never intended to work as a high resolution, live streaming video camera. It is designed only for use in video conferencing with web based applications.
06-16-2020 12:11 PM
Thanks!
I don't need it to be high resolution--I'm fine with the lower resolution. I'm streaming max 1 hour on IG and I read a Canon employee say that damage to the sensor & overheating is not a concern because you are not recording. While I understand your comment on its original intent, it was also not originally intened to be a webcam either so i'm just trying to take advantage of it's possibilities.
06-16-2020 04:46 PM
@lifelonglearner wrote:Thanks!
Correct! The cameras were not originally intended to be used as a web camera. But, that has changed.
Canon released a software package that allows many cameras to be used as web cameras. Again, the intent of the webcam utility is to allow the cameras to be used for video conferencing, not as a high resolution, video streaming device.
08-29-2020 07:33 PM
here is the trick:
start hangout select EOS W.U (must be able to see the live feed)
open obs select EOS W.U
close hangout and the feed will appear in OBS
enjoy!! and thanks to canon for the web utility 🙂
09-01-2020 05:43 PM
Hi, OP. I'm running into a similar issue. I have a brand-new MacBook Pro running OBS. I have a Rebel T7 and have downloaded the webcam driver for it. However, I only get a black screen when I plug it in and run it as a source in OBS.
The funny thing is that it works just fine on my older Dell Laptop. Picture looks pretty good and everything runs fine. The problem is that I don't trust that computer to properly live stream as it's a few years old and hasn't been reliable for some time now. Could it be possible that the Mac driver for the webcam app needs to be updated? I believe Catalina had an update in the last month or so. I'm no tech guru so I don't know what I'm talking about haha.
10-27-2020 01:10 PM
I'm getting a blank screen in OBS also.
My steps:
1. The utility installs appropriately;
2. restart my computer;
3. turn on the M50 camera to movie mode;
4. insert microUSB; connect lightning on mac;
5. I start OBS, add a new video capture device; it autoselects 960x540, but the preview screen and the main OBS screen remain black.
6. ...I double checked that the lens cap is off LOL
Does the camera's resolution make a difference?
Thanks for any advice!
cheers n' blessings,
G
10-27-2020 01:43 PM
10-28-2020 10:14 PM
10-29-2020 02:57 PM
