Canon EOS Webcam Utiltiy Pro will not install on Windows 11 Pro
jcjessup
I've got Windows 11 Pro on my home system and tried to install the Canon EOS Webcam Utility Pro software (from HERE ). The installation wa unsuccessful because my version of C++ was newer than the Canon software recognized. I don't want to have to uninstall/downgrade my software to allow for the installation (and if I did, I'd suspect the next Windows Update might re-update that and make it quit working again).
So is there a workaround for this, or is there a new version of the Canon Webcam Utility anticipated soon?
I need the ability to use the camera with the computer, but either need a workaround or an update to make it compatible.
Anyone else run into this and know how to make it work?
7 REPLIES 7
This is unexpected since later versions of C++ should be backwards compatible.
Visit Programs and Features.  Note the version of C++ you have installed.  Now uninstall your existing version.  Then restart.
Now run this.
Download Visual C++ Redistributable for Visual Studio 2015 from Official Microsoft Download Center https://share.google/8tgdgriCt4geHpzmz
Restart again and run the Webcam Utility Pro Installer.  . Please post your results.
Waddizzle
“ This is unexpected since later versions of C++ should be backwards compatible. “
I agree with Rick.  It should be backwards compatible.  Something could be out of order with the installation.
NoTrOx
See this service note posted on Canon's site.
Service Notice: EOS Webcam Utility Pro v2.3 | Canon U.S.A., Inc.
Their proposed solution did not work for me.  I wasn't able to get the webcam utility installed using their special C++ installers.  They say a fix is in the works...
ioldanach
I have the same issue. I have two newer versions of the Visual C++ installed and don't intend to cripple other software already on my system by downgrading to the version this app wants to use. I'll wait for this app to be updated with a current version of Visual C++.
This solution does not work. I already have this version of Visual C++ installed. The installer is requiring that its specific, older, version of Visual C++ be installed which the installer won't do because that would be installing a version older than the one already installed.
As suggested earlier, uninstall it and install the version specified.  Windows does not need visual C++ to run.  Once the software is installed, it may very well run even after Windows updates the installed version.  It won't hurt to try nothing's going to happen.  😉
knngredd0
this DOES NOT WORK!!!! still cant get my setup to work!!!
