EOS Webcam utility full version and MAC OS Big Sur
Ssalmorejo
I will like to know if anyone have the full version of Big Sur OS and EOS Webcam Utility full version working together. If theres any bug or trouble using both together. Thank you
74 REPLIES 74
Guys for me today it was just the Cable. I have like 10 USB-A to Micro USB Cable and just one Works... the one that came with the DJI Drone. The Cable is from DJI Drone.
12.03.2021 MBP 15 2018 with Intel + Big Sir workes Canon M50 on the latest 1.1.0
Zoom on the latest Software and the MAC itselfe on the latest software.
It was working since the first beta for Mac for me even though they explicitly mentioned it would not be possible with the native zoom app. Dont asked me why but it worked perfectly for one whole semester of uni. And today i was trouble shooting all day again becaus I sat everything up again today. And yes it took so lonf because I did not know that only on cable could make it work.
Also check: No Wifi/Nfc/Bluetooth on, No card inserted, use dummy battery for smooth experience, EOS UTILITY APP OFF
hello
I am running a very comparable set-up, also mac on latest versions (Big Sur and Zoom) and with an M50
so everything works
BUT there is a big latency on the camera (160-200 ms) so this gets annoying in zoom meetings for example because people hear the sound before they see my mouth moving
has anybody experienced the same? (already tried 3 or 4 different USB cables to no avail) and has anybody found a working solution?
thx
Pascal
wivibi
Does it only happen in Zoom or does it happen in all apps? Does it happen when you aren’t on a call? Might be a bandwidth problem.
no it actually happens in all apps, also in OBS
wivibi
What Mac are you using?
NotReallyMe
Ok, with the codesign trick the Camera now shows up in teams :). How can i disable autofocus in Teams Sessions for the Canon 5D MK IV?
wivibi
I would assume you could turn it off on the lense and camera
NotReallyMe
Sorry, i meant how can i enable it in teams. At the lens it is enabled, but during a teams session it does not adapt as a move closer or more far away from the camera. As the focus plane is very tight it would be great if the camera would keep the focus on me, as it can be enabled in the Canon software in live view.
FYI: On 3/30/2021 Canon released an update of the EOS Utility 3.13.20 for macOS for Big Sur.
After installing the update everything works again for me.
https://www.usa.canon.com/internet/portal/us/home/support/details/cameras/eos-dslr-and-mirrorless-ca...
wivibi
@notreallyme there isn’t an option for focus on TEAMS as far as I know. You mentioned you wanted a way to disable autofocus on TEAMS. I think you just need to disable it at the camera.
