01-11-2023 03:16 PM
Hello,
I'm running into issues with the EOS Webcam Utility Pro installer on a Surface Pro X running an ARM processor (Windows 11). The installer gives an error for the C++ Redist. 2015-2019 x64 was not correctly installed, even though the install proceeds with the correct ARM64 redistributable install.
Installing the C++ redistributable manually then running the installer provides the options to "Repair or Uninstall" but immediately provides the same error before it finishes.
Is there a possible fix or any plans for upcoming support for a Windows ARM installer for the software?
Thanks
C
12-13-2024 02:36 PM
Hi, everyone! EOS Webcam Utility Pro for Windows ARM is available for download. Just go right HERE.
Hope this helps!
01-11-2023 03:31 PM
ARM based processors on Windows is not currently supported. Will it be in the future? Maybe, probably. But I cannot say for sure. I'd leave [+}Feedback and make a feature request.
06-18-2024 02:28 PM
I am running into issues on my new ARM Windows device (Microsoft Surface Pro 11) - where is the feedback request form?
06-18-2024 03:16 PM - edited 06-18-2024 03:16 PM
Greetings.
Visit the Canon USA website. In the upper right-hand corner, you'll see a [+]Feedback button. Press it and select Product. Fill out the feature request form. 😀
Canon Homepage | Canon U.S.A., Inc.
12-13-2024 02:36 PM
Hope this helps!
03-17-2025 11:41 AM
Downloaded the latest version 2.3
Problem is still not resolved. Need urgent help to solve this problem. I am using Surface Pro 11 with ARM Processor
03-17-2025 11:57 AM
Hello, jedwin.
If you're using EOS Webcam Utility Pro V2.3b for Windows on ARM, and you need urgent assistance, please call support at 1-800-OK-CANON (800-652-2666).
03-17-2025 12:23 PM
What I had installed was 2.3a..... When I installed 2.3b, the problem is solved. I am able to use the camera as a webcam for zoom meetings. However, I am able to see only the person close to the camera. I am not able to transmit the video of all the people present in the room. Am I doing something wrong?
