05-27-2021 07:05 AM
Hello,
I'm failing to use my 600D as a webcam with the "EOS Webcam Utility".
It works OK with the standard utility, i can control my camera, record videos on the SD card, no worries.
However when i'm trying to use some other soft that see the virtual webcam "eos webcam utility", it only show the red x usb.
I'm running MAC OS X Catalina.
I've tried several ports, uninstalling and reinstalling, with or without the standard canon utility installed, nothing happens.
The 600d is said to be compatible, idk what I'm doing wrong, can you help ?
05-27-2021 11:05 AM - edited 05-27-2021 11:06 AM
This was all I could find for your model and OS. It has some hints and requirements. Have you tested with another USB cable?
EOS Webcam Utility 1.0 [macOS] (asia.canon)
05-27-2021 01:13 PM
05-28-2021 09:55 AM
Theres not many things to check.
USB cable or connection
EOS Utility is not running when you try to use the WebCam Utility
Security and Proivacy under System Preferences - Ensure the application is allowed and not being blocked by GateKeeper,
Camera is powered on when connected to the system
06-04-2021 03:47 AM
So I tried a new usb cable : same problem.
EOS Utility is not running when I use webcam utility.
The camera is of course powered on ^^
For Security and privacy : as much as I would like to add webcam utility in my "ok" list, the plugin does not create an app in the app folder so i can't add it..
06-04-2021 07:07 AM
@dongie wrote:So I tried a new usb cable : same problem.
It does not create an app. It is a device driver.
06-04-2021 07:21 AM
my point exactly. there's nowhere i could find it to add it as allowed program in gatekeeper
06-04-2021 09:47 AM
@dongie wrote:my point exactly. there's nowhere i could find it to add it as allowed program in gatekeeper
Do you understand what a "device driver" is? Does your thumb drive have an app?
https://en.wikipedia.org/wiki/Device_driver
07-09-2021 02:38 PM
If EOS Utility works on your camera, that should indicate that your USB cable is working fine. You should know that you need to exit EOS Utility before using EOS Webcam Utility. Apparently the two software cannot be open at the same time because they both need to talk to the camera over USB.
07-09-2021 04:04 PM
