EOS R: EOS Webcam Utility Pro does not work with Apple Silicon / Sonoma
majorpaul
I'm on an Apple MacBook Pro M2, Sonoma 14.4.1.  When connecting my EOS R, via USB, the screen on the camera shows that it's connected (the panel view is replaced with an icon), however the EOS Webcam Utility Pro 2.1.18 does NOT show any feed. It just shows a black screen with the white letters "EOS WEBCAM UTILITY PRO".
* This is regardless of whether I have any other software open or not.
* This is regardless of whether I have followed the legacy-camera trick, per https://support.apple.com/en-us/108387
(which one shouldn't have to do anyway)
* I signed up for a monthly subscription, hoping the full feature set on the software would enable something, but to not avail.
The only way I able able to get my EOS R to feed, now, is by:
1. Turning on the camera
2. Connecting via USB (no other video-capable apps open in advance)
3. Opening the EOS Webcam Utility Pro
4. Opening the service I actually want to use (FaceTime, OBS, Discord, Zoom, I've all tested successfully)
5. Closing the Webcam utility (!!!), and sometimes toggling between the EOS Webcam Utility option and things like the build-in camera in the OTHER software.
6. Keeping the other software open.  This maintains the feed/connection.
Any variation other than that and the icon-connection view just stays on the EOS panel and the Webcam Utility Pro shows nothing.
I cannot begin to describe the time and frustration now put into this problem.  Needless to say I will likely downgrade my subscription, as that did not help.
Any assistance is greatly appreciated in getting this to work as it always used to.
John_Q
Hello majorpaul,
It seems that you are following the right steps to get connected. We would recommend exiting and closing any applications that may be running on your computer, or in your task tray that may be connected to your camera, or using the camera’s Live View video signal. For example: Canon's EOS Utility or an application connected to the camera like another video conferencing app. When you connect the camera, there is an icon in the top right corner of your computer screen for EOS Utility. Make sure that you close that. It will keep the Webcam Utility from connecting to the camera. You can also press the shutter button half-way to engage the camera and activate the live image once you have that black screen.
2 REPLIES 2
John_Q
Hello majorpaul,
majorpaul
Thanks for the reply John!
I found another consistent way to get it working. The previous suggestion of exiting applications was not working, I would restart the system and *only* open the Webcam Utility Pro but it still would not feed.
That said:
* Open Webcam Utility Pro
* Turn on Camera -- disconnected from its usb connection but the other end of the usb attached to system.
* Attach USB to camera.
This is consistently working.
