11-14-2016 06:10 PM
11-15-2016 04:01 AM
"taking pictures of the super moon what settings do I use. I'm abeginner"
mommy,
Any astro shot requires several things to be successful. One is set the SL1 to full manual mode. Set you lens to MF not AF.
Use the Looney Rule as a starting point. It suggests f11, 1/100 SS and ISO of 100. I mentioned starting point because you want to bracket several shots by 1 stop. Do this in both directions I.E. a stop faster and a stop slower. Go several stops each way.
The Moon can really be shot anywhere but still a dark sky away from lights is best. Something in the 400mm focal length is a good starting point, too. You can use shorter lenses but you will have to crop the image severly and this will lose detail.
The lens will determine the tripod you need. The SL1 is not a heavy camera. It is possible to hand hold a Moon shot but it takes practice. Remember if you use the suggested 400mm lens it has a 8x tele effect. However, all the vibration or shake is also 8 times.
We were all beginners at oen time. Get out there a shoot the Moon. Next chance is 18 years down the road!
11-15-2016 11:44 AM
11-14-2016 06:25 PM
11-14-2016 06:32 PM
@kvbarkley wrote:https://en.wikipedia.org/wiki/Looney_11_rule
And a long lens, otherwise it will be quite tiny.
The Moon will appear roughly 30% brighter, so increase your shutter speed by one stop.
The Looney 11 rule the kvbarkley posted is a good starting point. The settings are not law. Experiment with different shutter speeds. I like to keep my ISO at 100 to get the lowest noise, but I've been known to experiment with ISO a little bit, too.
Use a STURDY tripod, a long lens, and a delayed shutter for best results.
11-15-2016 04:01 AM
mommy,
11-15-2016 11:44 AM
11-15-2016 04:01 PM
Any time, my pleasure!
