04-04-2014 10:10 AM
Hi Canon,
Just recently bought the T3i and am mainly interested in using it for videography. However, the recording length shuts down after 12 mins and then restarts again. I have heard this could be to do with the SD card. The SD card that I use is SanDisk class 10, 64gb Ultra, 30Mb/s. I have been told that this time could improve if I had a more expensive SD card; i.e. an Extreme Pro. But then again I read that 12 mintues auto shutdown is normal so therefore, an Extreme Pro won't make the difference. The 12 mins stresses me because I film weddings. (However, I do have a full hd camcorder as well which eliviates the pressure some what.) but would feel more comfortable with say 20 mins auto shutdown at full hd. Perhaps I need a different camera but I don't want to spend £200 more than I paid for the T3i. The other alternative is a software called Magic Lantern (ML). But what I have heard is that ML could improve this limit but would decrease the quality of the video. Not good. Does anyone know how much it would increase the video? To summarise, which DSLR is out there with 20 mins + and how much? Is ML a good option? Do SD cards have any bearing on the length?
Thanks in advance
Dominic
04-06-2014 01:49 PM
Hi canon people,
From what you guys are saying, pls correct me if I am wrong, the 44 mins refers to the amount of footage at 16gb it can sore. However, the t3i along with the t4i will both have a 12 minutue auto shutdown.
I gather it has something to do with them both having FAT32 BUT I don't really know what FAT32 is. I then assume a canon Mark 111 will have a higher FAT?
Thanks in advance
Dominic
04-06-2014 01:56 PM
The 5D Mk III can use exFAT. So it can go beyond the 4GB limit of FAT32. There would be some other problems making files much larger that 4GB anyway.
It sounds like what you want is a true video camera. You are talking about DSLR cameras that shoot video. They are not video cameras that shoot stills.
04-06-2014 02:02 PM - edited 04-06-2014 02:15 PM
All of Canon's newest cameras will allow you to keep recording video even if you reach 4GB. They do not "Shutdown".
The SL1, T4i, T5i, 6D, 70D, 5D Mk III, and 1Dx will continue recording but split the video into separate 4GB files.
exFAT is only used with CF cards that are 128GB and larger. The SL1 also uses exFAT so I assume all these newer cameras do as well.
This is what it says in the SL1 manual............
04-12-2014 10:22 AM
Thanks for the info. Much appreciated. Will check to see if it takes exFAT.
Kind regards
Dominic
04-12-2014 10:42 AM
T3i does NOT.
04-12-2014 11:56 AM
Thanks for letting me know
04-12-2014 12:36 PM - edited 04-12-2014 12:48 PM
According to Page 46 of the User's manual, your T3i does incorporate exFAT technology. The T2i and T3 also have it.
But..... exFat allows you to use SD cards larger than 128G. It will not let you record video files larger than 4GB because the camera is not set up that way. Even the 5D Mk III and 1Dx can not record video files larger than 4GB.
04-12-2014 12:56 PM - edited 04-12-2014 01:03 PM
If you are comfortable using "Magic Lantern" firmware on your T3i, you could also try a newer offshoot called "Tragic Lantern". Magic Lantern will not let you exceed the 4GB limit, but Tragic Lantern will.
More info here: Tragic Lantern for T3i
And here: Lengthen video recording time
