01-11-2020 04:41 PM
My camera is not turning on, I have no idea why this is not good help!
I last used it 2 days ago to take a picture, the battery seems fine but the camera does not register it being in at all, the battery is charged. What do?
01-11-2020 06:28 PM
There are safety switches on the battery and memory compartment doors. If the camera thinks either door is open, it will not power up. Also, a bad memory card can cause problems, so trying turning it on without the memory card.
01-12-2020 12:50 AM
Hey there,
In addidtion to checking that the battery and memory card door are properly closed, it is always a good indicator to check that either a second battery works on this camera or that your current battery works on a second camera body if you have access to one. If a second battery is no good then the camera may need repair service, but it may be that the battery just needs replacement.
https://www.usa.canon.com/internet/portal/us/home/support/service-repair
