Reply
Occasional Contributor
Flash busy
Hi, when try taking pictures with AF, the flash don't take pic, on the screen appear busy. Thanks in advance.
Re: Flash busy
Sorry my camera is EOS rebel t6
Esteemed Contributor
Re: Flash busy
have you tried a new battery?
Re: Flash busy
Thanks. But my camera it's new.
VIP
Re: Flash busy
If you see that message in the viewfinder, along with a lightning bolt, then the flash is simply recharging.  Be sure to allow adequate time between shots for the flash circuit to recharge.
Another cause for the message is long exposure noise reduction, or high ISO noise reduction.  The final cause could be that your memory card is flawed or failing.
Re: Flash busy
Thanks so much for your advice. When use MF I don't have any problems.
Re: Flash busy
My camera it's new. Where can change long exposure noise reduction and high ISO noise reduction?
VIP
Re: Flash busy
Switch the camera to <P> mode on the round dial on top of the camera.  You will find the options in the menus.  If you are saving images as JPEGS, then you may wish to leave the settings enabled.  Just be sure to have sufficient light when you take photos.
Re: Flash busy
OK Thanks. I appreciate it your help. Finnaly, where is the settings savings images as JPGS ?
VIP
Re: Flash busy
With the camera in [P] mode, you can find that setting an many more in the menus.  Also, that settings is one of the available settings on the "Quick Menu" screen, which is the one that appears when you press the <Q> button.
powered by Lithium
