12-20-2018 08:30 PM
12-21-2018 12:06 AM
Hello Ohiobudd,
The camera is not able to connect to a phone or other mobile device through a hot spot or mobile cellular data.
12-21-2018 12:12 AM
12-21-2018 08:39 AM
I believe the HDMI jack on your phone is an output only, so no you cannot do that
12-21-2018 05:23 PM
Ohiobudd,
With the camera's WiFi enabled, you can establish a connection to the phone. It does not require externally available WiFi.
There are no provisions to utilize a data transfer to the mobile in this manner with an HDMI cable.
12-21-2018 05:31 PM
12-21-2018 05:48 PM
Go into the WiFi settings on both the camera and phone and make sure they are both on the same network. I ran into this problem when my phone was on a 5ghz WiFi network at home and my camera was only capable of being on my 2.4ghz WiFi network. Once I switched my phone over to the same 2.4ghz network they connected.
