12-08-2019 12:11 PM
I am downloading Latest Digital Pro Software for my Rebel T5 but directions for downloading says to key in the serial #, but it is mostly worn off the label the only nunbers i can read are the last six which are 002026. What are my options?
12-08-2019 12:31 PM
Do you still have the box? The serial number is on the box too, it is also in the EXIF data of your JPEG or Raw pictures but the catch there is, I think, that you need the Canon software to access it or maybe some other software can access that EXIF file if so then follow this:
If the serial number on your EOS camera has either rubbed off, or the sticker on which it is printed has been removed, you can still locate the camera’s serial number via EXIF data.
Simply open one of your images (RAW or JPEG) in Canon’s Digital Photo Professional software (free in the box with every EOS camera) and then either right-click and choose ‘Info...’ or select “File’ > ‘Info.’ Either of these will bring a pop-up window that displays various file EXIF information. Towards the bottom you will find an entry named ‘Camera Body No.’ - the number here is your camera’s serial number.
12-08-2019 12:31 PM
12-08-2019 02:41 PM
12-08-2019 02:55 PM
Glad we could help you and you're welcome!
