06-11-2013 08:20 AM
My old computer downloaded files in a 4 digit system just fine, windows 8 somehow will not . I dont think i changed anything but this will drive a person nuts when you are looking for a certian file that has a 4 digit file number. Having multiple files with oo1 but different dates makes it nearly impossible to search.
06-19-2013 06:32 AM
06-17-2013 05:44 PM
Hi Hooperjohn,
Which camera do you have?
With which software are you transferring your images?
If you're using Canon software, have you updated it for Windows 8?
06-19-2013 06:32 AM
06-19-2013 07:55 AM
What about just using a card reader instead of a direct hookup? Computer should see the card just like a disk drive and maintain the file naming on the card.
Just a thought.
06-19-2013 08:23 AM
06-19-2013 07:54 AM
The windows update seems to work but it did open a new can of worms to use the new image browser. I still will use my old system (CS6) but this new way has some promise with some of the features that look like i might be able to use.
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.02/07/2023: New product announcements!
