upgrade to 6D from7d - flash& wifi issues - worth upgrade?
tws_canon
Dear Friends,
At present I have the following for about 2 years:
7d
canon EF-S 15-85mm
canon EF 24-105mm L
canon EF 35 mm f2
and Blackberry 9900
I am considering to sell 7d & EF-S lense for 6d and use L lense with the new body.
The main purpose is general usages, and also for work, indoors, outdoors, travelling and family photos.
others features aside, only 2 matters remain: WIFI & Built-in flash.
can I transfer photos from 6D directly over wifi to Blackberry?
Does it work well?
or, Alternatively, shall I buy Wireless Transmitter WFT-E5A for 7d instead? does this work with BB?
with 7d, after taking photos at work or leisure, I am "forced" to go back to laptop, plug cables,
and send via BB to customers/ friends. If 6D can do this wirelessly, it will be ONE of my big upgrading point.
please help on this matter.
I use 7d built-in flash like 90% just for fill-in flash during the day, high contrast areas or at night for lighting up the subjects. 6d has none (and I am not considering buying any speedlites yet)
Will I still be able to achieve good photos with 6d?
Can 6d handle high contrast area without the fill-in flash?
thank you so much on your inputs in these 2 matters.
3 ACCEPTED SOLUTIONS
hsbn
Whiz
The wireless apps is for android and ios only. I do not know if the wft-e5a will work or not.
Nothing can replace fill flash. Without fill flash you will have to over expose the ambient in order to fill the shadow.
If those two are your reason to update then it is not worth it.
Weekend Travelers Blog | Eastern Sierra Fall Color Guide
HSBN makes good points, doesn't sound like the 6D is for you.  If you really use the flash 90% of the time, then it's a no-brainer.
I like the 6D a lot, but I wouldn't buy it because of the WiFi.  It's nice to have, but it's really not a feature to weigh too heavily yet.  It's still a very young technology with a lot of things that need to be worked out.
ebiggs1
Keep your 7D.Smiley Happy
EOS 1DX and many lenses.
6 REPLIES 6
hsbn
Whiz
Dear HSBN,
noted your comments and thank you kind feedback.
ebiggs1
Dear Skirball,
Thank you for your kind advices.
I'll keep my 7D for now.
Dear ebiggs1.
thanks and noted your advice.
I'll keep 7D for now.
