t7i uses maxium ISO when in Auto Iso - no matter what setting I use
feedrail
i use auto iso in shutter priorty (TV) and no matter shutter speed 100 to 2000 its shoot at my max setting 6400? What up? Also if I use it in AV no matter the setting it shoots iso 6400 or if I set max to 3200 all shots are shot in 3200.
Thanks
11 REPLIES 11
jrhoffman75
Are you outside in daylight? What are your lighting conditions.
R6 Mark II, M200, Many lenses, Pixma PRO-100, Pixma TR8620a, Lr Classic
feedrail
It doesn't matter it can be full sun and I can set shutter to 1/30 up to 1/1600 and it has no effect
What lens are you using?  It sounds like the automatic aperture might not be working.  Try a different lens.
You could try clearing all camera settings and custom functions just in case you inadvertently set something you didn't want. If that doesn't work give Canon a call at 1-800-OK-CANON.
ebiggs1
"...its shoot at my max setting 6400..."
What is your minimum ISO setting?  Did you check it?
I don't believe Rebel series allows a minimum ISO to be set.
It's been too long since I owned a Rebel to remember.  Just a shot in the dark.
feedrail
I use 100-400 5.6 tried different lens. What ever I sent the max ISO for auto I use, that's the ISO it uses.
What happens if you set it to P mode?
What Av value is the camera setting when you are in Tv mode?
